Stirling
- Dec 11, 2013
- Alberta canada
is my only option to send it back to manufacture or is it possible to do by myself in the shop? (manufactuture depo is thousands of kilometers away)
i belive its slipped enough to start causing intermitent problems. the servo is flagging several errors off and on. overtravel, signal oversaturation, overload, out of range...
it seems like the encoder is juuust out of alignment enough that the motor "overworks" to hold position though there is no load, causing heat build up and errors to flag when in use, or upon start up it likes to "jump" a few inches if its not hommed quickly.
the reason i think it not clocked corredt is becouse ive had the servo apart before (intigrated break problems) and attempting to reasemble it, these same symproms occured
ive managed to reasemble this once by inching it along the axisapperently got very lucky and it worked, another time i spent 2 days inching it and no luck :/
So.. any tips,tricks, software i can use to tackle this, or am i shpping it accross the whole country?
apperently new ones are not availble (its a 2005) and a new style would rewuire a controler retrofit rendering the lathe scrap at that price.
