PeteM
- Jan 15, 2002
- West Coast, USA
Just to add to all of the above good advice, measurement pressure can make a couple tenths difference in readings. That's why mics meant to measure tenths or better have some method of controlling and sometimes indicating pressure. Your customers probe may be gently touching, while your mic anvils are tightened down a bit on the part. If you're hand holding the mic, that bit of extra heat can also open up the frame a bit and give you lower readings.
Part of this pressure effect on readings can be surface finish, but another part can be flex in the mic body and a bit of give in the thread/nut.
Could be you and your customer will get closer agreement if you take this variable out of the mix, perhaps by using an indicating mic held in a stand and measuring with whatever light pressure (and room/part temperature) gives best agreement.
I'm assuming here that lobing has been ruled out. If not - a two point mic isn't the right tool.
