We are currently setting up a new facility under AS9100. We have previously been able to avoid some inspection equipment with other methods, but in the direction we are going, a CMM on the floor is likely going to be required by our customers. Whether we 'use' it or not, whatev, but they will want to see that we have one. The space that we want to allocate for the inspection room only has I think 9ft ceilings. Now I have been around small CMMs, but I think we will need to step up a bit, but I know we cannot fit what some shops have, which is like an 8x12ft granite and probably 12ft high. Based on part size at this time, I would say probably roughly a 4x4ft granite table would suit us, but not sure on the Z. We really don't need monster Z travel. I would say 36" would work.
As well, I wanted to ask if any of you guys are in a high end quality dept, are Faro arms becoming more accepted at a method of final inspection, FAI, etc? I know several years ago when I approached this bridge, I did not get positive feedback from customers, but they were still sort of getting proven out I think.
I will say this, we might have to buy a CMM, but I am still looking for acceptable methods for inspection that are more efficient. The Faro is far faster, and many of the parts we do, we are able to prove them out with a digital height station. But if we are talking about using the CMM, it might be prudent to consider the software? All I have seen is quite proprietary and they want to hook you into contracts, etc.??
