gcarmichael
- Aug 24, 2022
I've designed a splined prop shaft and gearing for a 15HP outboard engine using Fusion360 (model overview attached). I created this design to replace the standard 2:1 gear ratio with a 1:1 gear ratio. I printed the parts in 3D in PLA to ensure fit and function. I want to have these parts manufactured in 15-5PH Stainless Steel and believe that CNC would be the best method. I've submitted my designs to Xometry and Fictiv for a price quote but both companies have said that they don't have the capabilities to manufacture these parts and ensure strength and functionality. I have done the calculations and verified that all parts are properly designed to support the real world use cases if manufactured in 15-5PH.
This is my first time to use CNC as a production method and I am unsure if I have issues with my designs as far as CNC production goes and who or how I contact a company that can produce the parts for me.
Any guidance on producing this assembly would be appreciated.
Thank you,
Gilbert
Thank you,
Gilbert
