CNC Write Engraving Software
cdw3423
Jun 3, 2022
Several years ago I wrote a simple program to generate G-Codes for engraving text with CNC machines with either a linear or rotary axis.
Recently I have decided to start making videos on how to use CNC Write. I just posted the first one, "CNC Write Introduction" on YouTube.
I hope to post a video every week until I have covered all of what you can do with CNC Write.
Hopefully it will help those who use the software or are wondering if it is something they might want to use.
Here is the first video.
cdw3423
Jun 3, 2022
It does, watch the intro video, I have an example of it doing just that.
If you skip to 5:30 you can watch just that example case.
cdw3423
Jun 3, 2022
The third video is now up on YouTube. This is the first video that goes into detail on part of CNC Write. This one covers the Text Parameters and Justification sections of the interface.
Philabuster
Jul 12, 2006
Tempe, AZ
Subscribed to your YouTube channel. This is pretty neat. Not sure I will ever need to use this on my Integrex, but it would be fun to play with it.
cdw3423
Jun 3, 2022
The 4th video is up. This one is the most complex. Hopefully I explained everything well.
Vancbiker
Jan 5, 2014
Vancouver, WA. USA
Since most CAD/CAM software offers engraving functions and most everyone is using CAD/CAM, hard for me to see good use of a separate software just to engrave. What am I missing?
Philabuster
Jul 12, 2006
Tempe, AZ
It would be good for the Mazak crowd as many of us do not need to use off-line software to program the Mazaks for everyday parts. This can be added as a sub program.
cdw3423
Jun 3, 2022
When I was asked to create CNC Write I was told existing software was hard to use and when engraving on a curved surface the XYZ interpolation used by that software makes the engraving very slow. And I also was told that none of them use a rotary axis to engrave on a cylinder. CNC Write is very fast to use and the engraving it does is also very fast. I know that Oil Field Equipment Manufacturing companies like CNC Write partly because the stress created by impact engraving that is commonly used by some shops is not allowed on that equipment.
Mtndew
Jun 7, 2012
Michigan
I don't know who told you this but they couldn't be more wrong.
But kudos to you for having the knowledge and ability to write a program like this. Makes me almost want to learn code programming. Almost. ;)
cdw3423
Jun 3, 2022
That could be, and I could be remembering it wrong. It was all the way back in 2007 or 2008. What I remember for sure was they were willing to pay for the development and I have had quite a few happy customers since then.
cdw3423
Jun 3, 2022
The home shop harry market would probably be his biggest customer base.
CNC Write is intended for serial numbers, part numbers, an other utilitarian text on parts. There are no fancy fonts to engrave with, so I'm not sure why a home shop would want to use CNC Write. I also doubt many home shops can do Rotary Axis engraving or have mill-turn machines.
Mtndew
Jun 7, 2012
Michigan
Ahh, ok. Serial numbers is a big issue for most cad/cam programs. You would think that would be the opposite give the fact that so many parts require serialization.
Vancbiker
Jan 5, 2014
Vancouver, WA. USA
Serialization is easily handled by a macro. The characters used by a macro can be generated in any font the CAD/CAM supports.
Outside of probing, serial engraving is one of the most common uses of macro programming.
cdw3423
Jun 3, 2022
Video 5 is up. This one was a lot easier than the last one. While getting ready to make this video I decided to make a minor change the the circle and ellipse tabs. I use the ellipse text tab in the example for this video.
