Do not use TiAlN on aluminium. Strange sticky things happen between the Al in the coating and the bulk aluminium. I haven't seen AlTiN but the same would apply. Zr coatings are recommended for Al.
Cheers
Roger
You shouldn't, but you can.. I'm doing it right now, I can hear the chips moving as I'm typing.
You do end up with a weird aluminum smear on the flutes, and I only do it when I need a specific
radius, and I only stock oddball corner rad endmills for steel.. I don't do enough aluminum to
stock that shit too...
My understanding of endmill coatings, and its probably all wrong.. AlTiN, TiAlN. As far
as I'm concerned, its the same damn thing, somebody had to be "cool" and change it up..
The dark purple stuff.
When it gets HOT, like really F'n HOT!!! 1700F'ish.. It gets harder than hell, I vaguely
remember reading well over 100+ on the C-scale, and it gets slicker than snot. I'll run
this on dry on mild steels, 4140's, 1018 type stuff. Wet in Ti, and stainless.. Depending
on how you are running you can get away with dry and faster on some stainless. 17-4 is an
odd duck, in the solution treated state it behaves very much like a "stainless", but once
heat treated it loses almost all of its "stainlessy" properties (cutting wise) and responds
more like a carbon steel, and is perfectly happy running dry.
Then you have the light purple pink stuff TiCn, comes into play at a lower temp.
Haven't used this in years, though I would use it on aluminum, and on steels when
I was hanging out and running slow and wet.
Then you have TiN, the gold stuff that comes on chinese endmills.. They sell it down
at the hardware store in the spray paint aisle.. Its labeled as "Gold Spray Paint".
Apparently it does something, but I dont' know what.
Coatings for aluminum, I don't have a clue..
There is also all kinds of new fandangled BS out there, and I'm sure a lot of it works a
treat.. But I don't have time to deal with all that crap... Pick up the phone or fire
off an e-mail.. "Send Me Something That Will Do XXX"
