Have a Colchester Master with alot of wear in the ways just before the headstock, .020” in one section. This is enough to make it difficult to use when alternating between different lengths of materials without making adjustments to correct.
One idea to improve things is to have the bed ground, this will help remove the error from the bed way. I realize that most likely a major part of the wear is going to be is in the bottom of the saddle, as this area is not hardened.
I understand that the wear to the underside of the saddle can be compensated by applying Rolan, or Turcite then scape these areas to fit. It sounds like Applying Turcite to the bottom of the tailstock is not the best option, better to machine and scrape these areas then shim to adjust for elevation.
My question is how do you arrive at the elevation the saddle needs to be to maintain the correct contact for the carriage drive gear. It is obvious that on my machine the contact between the gears is not correct now.
Hopefully there is a better method other than trial and error.
I am not particularly looking to return the machine to its out of the factory tolerances, more wanting to make it a useable machine once again.
