Colchester Triumph 2000 - Jaws
Jul 28, 2023
We are looking for new jaws for our Colchester Triumph 2000 Lathe - don't need the chuck.
3 Jaw - U62 serial number on the jaws.
Chuck - Serial Number BP73/9234
Photos attached.
Does anyone have any idea where we can get these form?
Thanks
If the above link does not provide what you are looking for, you can try PrattB. You can even try mix and match from other makers - but it is a crap shoot (I needed pinions for a nameless 3J, Bison pinions were a spot on match).
In Strictly practical terms, just go purchase another chuck (a set of proper hard jaws from the manufacturer will likely be more than 50% the cost of the chuck, and you still have an old chuck - seems that way with all the manufacturers).
Now practicality aside, it is not difficult to make your own jaws (just time). Harold Hall describes a method using manual machining. I made a set for a 12” 3J using a CNC - it is simply a declining radius spiral (short section of), then translate the pitch of the scroll times the number of teeth, repeat two more times with the origin shifted by 1/3 of the scroll pitch. Harold explains it quite well. The slots are straightforward, the jaw angle is mostly cosmetic and the grip surface is machined after assembly (with a loading ring).
Like most things in life, once you know how, it is quite easy.
