justmakingchips
- Oct 8, 2015
I could use some help with these new parts. I am making some parts out of round S7 that are around 10" long. The parts have a linear hole thru the entire length that is .204" in diameter that we are doing in a gundrill application. Then the part has a bore in the one end that is .427" in diameter that is roughly 2.5 deep. The two bores have a callout of less than .001" concentricity. We have failed in this area several times in the past and could use some help on machining these bores. I have tried gundrilling the .204" bore thru and then using a 3 flute c'bore bit with the pilot ground to .2035" with no luck. Any advice would be appreciated!
