RDurrant
- Apr 30, 2007
- Justin, Texas
Wanted to throw out this idea (not my own) and see what information might be had by the gunsmith machinist community.
I recently moved to Texas from Utah. Kind of a big mistake as now I don’t have access to any land to go shoot or hunt. But I digress.
I have a Standard Modern 11" x 34" Series 2000. Just before I moved I bought it for a deal I just couldn’t pass up (free). I never really used it because the foot it was attached to was just some old pipe stand. Not very rigid. I tossed the stand in Utah before I moved.
That being said, I need a stand.
I read a while ago about a guy that was thinking about mounting his lathe on a set of poured concrete pillars as a stand. I thought it was a good idea but for the possibility of the shrinkage of the concrete over time. Thought maybe using cinder blocks filled with concrete and rebar might work a little better. Don’t really know.
My idea of the stand is this: Pour a wider base than the top for stability using reinforced concrete. Seal it with some type of concrete sealer or concrete paint. Construct a thick steel mount pad to epoxy to the top of the concrete mount at each end of the lathe bed, allowing me to shim the bed level etc. and bolt it solid to the concrete stand.
Feel free to comment on this project, all ideas are welcome......Thanks
