Conditioning Rings for a Flat Lap: Possible to Make Your Own?
dian
Feb 22, 2010
ch
We have a 12" Lapmaster at work, but I built a small one for home. You can probably find cast plumbing fittings at a good hardware store. Face the end and Bob's your uncle. Note that the factory ones are pretty heavy and slotted; getting those is best if you can afford it. Make sure you rig up an indicator bar so you can monitor the lapping plate flatness. It takes very little time to make it go convex, but near-to-forever to correct the problem. So long, in fact, that it's easier to just send it out and have it surface ground.
plumbing fittings? what kind do you have in mind? op needs roughly 5" rings, right?
Conrad Hoffman
May 10, 2009
Canandaigua, NY, USA
Start with a search of 4" schedule 40 steel pipe. I think that's 4.5" OD. Should be a bunch of related fitting and stuff, though maybe hard to get. Or, just look at the various fittings in a well stocked hardware store. Stuff like couplings and flanges can be pressed to service with a bit of machining.
