Jeremy Sawatzky
- Nov 16, 2021
I have a new to me 1998 Daewoo Lynx 200B Lathe with a Fanuc 21-t control.
My issues are when I try to reference (home) the machine. The z axis works fine. If I am near the chuck, it rapids away until its about 3" from its home and creeps until it hits its reference (home) position then stops and the little green led lights up.
The X axis rapids upwards until its hits its soft limit. No reference limit, no green light. I have tried to change all of the parameters associated with this action. But I have had zero luck in adjusting the "home" location.
Below is a list of the parameters I have been adjusting. - I will put a P next to the parameter number otherwise its sort of confusing.
Reference Point #1 P1240 x axis 250825 - went up down and nothing changes
z axis 419100
Reference Point P1250 x axis 250825 - went up down and nothing changes
z axis 419100
Reference Point (inch) P1251 x axis 98750 - went up down and nothing changes
z axis 165000
Limit + P1320 x axis 279400 - adjusted to 170000 because it was way beyond the hard limit switch for some reason.
z axis 435340
Limit - P1321 x axis - 40640 - adjusted to -110000 again because it was way off its mark
z axis 104140
I have also tried moving the machine to where "home" should be on the x axis and toggling the 1215 Parameter APZ to 1. then power off then on. Plus many other combinations of messing with that bit but to no avail.
I also reset the soft limits by powering down and holding CAN and P while powering up but again to no avail.
Is there something in the gridshift I should be messing with?
Thanks
z axis 419100
z axis 419100
z axis 165000
z axis 435340
z axis 104140
Thanks
