Metal-Masher
- Dec 5, 2018
It's a regular SB 18DP gear as used on the workshop series 9"
Someone just did a terrible bung up job on it....shame because it looks to be in otherwise nice shape...good news is you can bore it out, and press in a new sleeve with a 9/16" bore and 1/8" key way and you will have a fine gear...loctite and Dutchman pin the new sleeve in.
I have used this method a few times myself, and while not the "best" way to do it, when it's all you have, it's a perfectly acceptable way of accurately putting in a key way.It's rather simple to cut a keyway with just a boring bar and your carriage. It's a poor man's shaper. Put the correct profile bit in the bar, set where you want the slot, then advance the carriage by hand thru the hole to remove ~ 0.002". Move the cross slide out another 0.002" and move the carriage again, cutting another 0.002" out. Repeat, lather, rinse, until you have reached your desired depth. The lathe is NOT running while performing this operation and the spindle is locked in one position.
Unless you're really fast with that carriageThe lathe is NOT running while performing this operation and the spindle is locked in one position.
Notice
