scsmith42
- Jul 28, 2020
- New Hill, NC
Years ago I owned an automotive machine shop and worked on a lot of heads - including welding them up and reprofiling combustion chambers and ports.
The advice from others in this thread is valid. Diesel engines have extremely high compression ratios and also internal harmonics due to the combustion process. To properly repair that head, it needs have both pre and post heat after the repair is made. As I recall, post heat is a 24 hour process.
If the tractor means that much to you, drop the grand in the properly repaired head, or better yet contact the repair shop referred to by Garwood above.
Best of success to you.
