Crankshaft grinder steady rest
Dave123
Jan 13, 2019
Have recently purchased a Storm Vulcan 15A crank grinder.
The unit came with two steady rests, however one of the rests is missing the upper contact arm, easy enough to make one, although I don't have easy access to babbit for the tip,...wondering how bronze would work as a replacement?
Dave
johnoder
Jul 16, 2004
Houston, TX USA
Brown & Sharpe sold both WOOD and bronze shoes for their Universal Back Rests for their Universal Grinders
Here are some hardwood doing an okay job in a lathe steady
Heavy crank shafts might need more "substance" - like Bronze
Dan from Oakland
Sep 15, 2005
Oakland, CA
If ya need some babbit, send me PM. or just make them outa lead. Its a crank grinder, you're not grinding steel mill rolls on it. Also, check the Goodson web site- I recall them having them in their catalog at some point. Also, John's suggestion of using some wood is not out of question.
Turnaround007
Dec 27, 2019
You would only be able to use two steady rests, at one time, for grinding mains. If you are using lathe style chucks, instead of grinding between centers, I doubt if you would benefit from two steady rests as a single steady rest usually goes on the journal that you are grinding. If you choose to grind between centers by using a lathe dog to drive the crank, you will run into errors on the front center of the crank's snout, caused by folks using harmonic balancer pullers which have a habit of digging up the snout's center vee surface.
