Thanks and yes it's Onshape. I started using it because it was free and the idea of using it out on the floor with a touch screen tablet seemed fantastic. Then I realized how hard it is to select tiny features on a little screen with my fat fingers
. Now I mainly use it via desktop.
I was thinking about parting it down the middle parallel with the "right" side pictured (the hollow collar on the back would either be cored, or solid and drilled out later. I did the model as close as I could to the drawing with the intent on adding draft and other features to it once I either had a 3D print in my hand to physically play with, or had a foundry point out what they needed me to change.
I think we had talked about this project a couple years ago. My hope is to produce a loose plastic pattern via 3D printing that I can then pass to a foundry to use, or split the model and attach the halves to a mold-board, adding a sprue and vents as well. In the past my dealings with foundries lead me to leave all the pattern building and modification to them, but stuff like this it isn't really financially feasible to do that, so you either need to work closely with the foundry or know your stuff enough to do it all yourself without their help. In some ways, DIYing patterns feels like counterfeiting money, trying to see if the foundry will take your results or call you out as a fraud. For this project I hope to get three castings made, however it's a part that could potentially see later use to other users, so having a pattern (however rough and tumble it is) could be useful in the future. It's just the classic struggle of trying to avoid putting too much time and energy into something that might only get used once.
