FredC
- Oct 29, 2010
- Dewees Texas
Customer sent me several prints with difficult tolerances. I emailed back and expressed reservations about holding the tolerance in the long part. This is on a 5 inch long aluminum tube with a 1.000 OD and an .8700 bore plus 0 minus .0004 on the bore.
The engineers reply "I just found I had left over McMaster-Carr 89965K681 General Purpose Aluminum Tubing from last time we made this and the ID is undersized. So I only need it Cut to Length, Reamed, and Plated." Plating will be clear irridite. The best I can tell is this will add nothing to the material.
Other close tolerance items in this package:
1/2 long bore .7495 same tolerance plus 0 minus .0004 on the bore (6061)
1 inch long bore 1.1248 plus 0 minus .0004 on the bore (6061)
1.0000 bore 1/4 long in Nylon plus or minus .001 Would have been comfortable in PEEK with this tolerance but nylon?
Thinking about asking the customer for the parts these fit and asking what kind of fit they expect. I do not think they can even measure this stuff, just put numbers on the drawing with the expectation they will be close.
Any other suggestions?
We hold closer tolerances down to plus .0001 minus 0 in small parts all day long. We use Deltronic pin gauges, super mikes laser mikes, and such in production parts. No way I can justify the gauges for 1 part of each on these things.
