dalmatiangirl61
- Jan 31, 2011
- BFE Nevada/San Marcos Tx
Its been 24+ hours, what worked?
I hear hexagons are also a nice shapeI will not know for a week or more. I am moving and I found my smaller hole saws and arbors. I think I have a hole saw of the correct diameter but I have to find it. I will see if I can buy a narrow blade for my oscilating cutter to make short chord cuts to form a circle.
Bill D
I have used pipes with a sharp inside surface bevel. The pipe section is chucked into a drill press.To go under I need to cut two six inch diameter holes for the lathe feet pads. I was thinking hole saw or jig saw. Mat is too big and heavy to use a flycutter in the drillpress.
Grind a piece of 6 inch pipe and pound it thru the MattI have used pipes with a sharp inside surface bevel. The pipe section is chucked into a drill press.
At medium speed it passes straight thru with nice smooth surface finish.
On your job I would buy a 6" galvanized pipe nipple 1-2 inches long and a end cap.
Remove the thread on one side of the nipple and sharpen the inside edge.
Drill a hole in the center of the cap and weld or bolt on a 1/2" bar about 6" long.
Screw on the cap. Chuck end of bar in drill press. Now you can go through some rubber
Use a plywood base underneath the rubber mat when making the cut.
Matt would report you to the Poooolice... But Mat would not.Grind a piece of 6 inch pipe and pound it thru the Matt
Don
Notice
