SBAER
- Aug 21, 2006
- Kitchener, on canada
I put the numbers best I could into my MITcalc gear software. 11 tooth 20 PA pinion with a center distance of 12mm (which is what a 12 tooth with no addendum mod would be at). The OD comes out to 28.01mm when I do the the addendum mod required to put an 11 tooth pinion on the 12mm center distance. I have attached a PDF and a DWG file of the gear but don't have a way of checking the dwg file on this computer. It looks like you could hand grind a single tooth cutter as the undercut appears very small. I am no gear expert, just trying to help.
Google Drive: Sign-in
