thermite
- Sep 21, 2011
"Relying a powerful heap on my memory" to quote Granny on being asked to klew Ellie Mae about sex, one Beverly Hillbilly skit..Bill my Sb bearing are round and actually smaller then the spindle shaft.
There’s a tapered brass expander at the top that gets pulled up and out of the bearing to expand the bearing shell open allowing the spindle to fit.
If you loosen the screws to that expander the spindle LOCKS right up solid, not because the expander interferes but because the ridged bearing shell clamps back down tight almost like spring steel.
The expander is bolted solid to the top bearing cap with no adjustment.
The caps are lifted with shims to pull the expander up causing the bearing shell to expand.
....given I did this but ONCE, and about 1962..? The SB. Not Ellie Mae.
By 1959-60 the 2 1/4"-8 was it? Spindle 10" "Toolroom" with all the decorative but useless flaking, there was a longish steel bar at top, rounded ends and two submerged cap screws to do the adjusting.
When asked by other Students why I was always on the same week-installed plain looking roller-bearing Logan, not the "pretty" SB?
"Because I have earned first choice."
thermite liked this post
Works for me!
PS: YEARS go by.... scores-of... C&W Mercury Communications is established, UK.
Old mate of mine from Bermuda is installed as MD. I look him up in the new phone book, and ring him up.
He is not the most handsome guy around, wears a beard like cousin James Ewall Brown Stuart, nicknamed "beauty". "JEB Stuart" came later. Because back of his scraggly beard? He were anything BUT a "beauty"!
"Ian? How the Hell did the MD end up with "666" as his phone extension?"
"I got first choice!"
