M. Roberts
- May 11, 2021
People, I hope all is well. I have a occurring job which involves wire EDMing a 16.5mm OD x 10.5mm ID x 100mm tall tubes from a block. I EDM drill the starter holes for the ID of the parts. My current method as stated, is/was to pop in the starter hole, wire out the ID, leaving a tab to hold the core, cutting the wire, and jumping to the OD, and cutting it; then when the OD was done, snap out the ID core. This is leaving an undesirable burr on the ID that I would like to make better. Yes, I could break the core out prior to doing the OD, but that would really throw a wrench into the desire to run "lights out".
I had the thought of cutting the ID complete, cutting the wire, rapiding out of the way (in this case, the Y+ direction), letting the core fall, then index over to the next starter hole, and repeat. Part of my issue (I do have issues) is that I cant find the happy medium where the code and the core meet...meaning sure, I can program the ID circle complete, but sometimes the material fractures prior to the completion of the cut, and it shorts out..make sense? Is there a code that if the machine senses a short, it will automatically cut and jump to the next line of code (2003 vintage Sodick AQ750)? Another thought; is it possible, that once the cut is complete, to rapid the Y and V axis separately, and use the upper flushing jet to push the slug out of the cut?
I'm open to ideas!
Thanks, Mark
I'm open to ideas!
Thanks, Mark
