Hello everyone,
seems like the new year brings me new Problems
After starting up my FP2NC yesterday morning the CRT just shows a line.
This is one of these unexpected overnight problems...
The line "matches" the set machine mode and I can jog the Axis, run the Spindle and change Tool.
For me this indicated a failure of the CRT itself or a bad CRT controller board.
I ruled the CRT out, using a cheapo DSO Oscilloskope. There was no measurable Signal on the vertical deflection grid.
According to the schematic of the NDM51 Board the vertical deflection is controlled by a single TDA1170 chip with a ELCO in the output signal line.
I will now change the TDA and some of the electrolytic caps on the board.
If this measures doesn't work, I probably will have to bite the bullet and buy a replacement NPM51 Board or swap out TFT...
Has anyone of you run into similar problems?
Is my assumption with the broken parts right?
Kind regards,
Markus
Kind regards,
Markus
