Deckel Maho MH 600 E (Philips 532) replace backup battery
MahoMachinist
Oct 11, 2022
Hi,
This is my first thread at this forum, I have a Deckel Maho MH600E machine that I need to replace the CNC battery in (got alarm message: O 23).
The CNC control is Philips 532.
Unfortunately I don't have much documentation to the machine, so I don't know what type of battery it is and where it is located?
The first thing I did when I bought the machine was to take a picture of all the machine constants (at that moment I didn't have any cable for DNC), so I have the parameters stored.
I would really appreciate if someone could please help me, I have a customer job that needs to be done in the machine and I don't have any other machine for it.
Regards from Sweden,
MahoMachinist
Hello MahoMachinist,
Can you please provide us with the software id number, so we can give further information? It sounds like you have the 532 LBX bus-version. A battery change would mean that you would lose all the machine constants, so you will definitely need them.
Regards,
PGH Team
Hi, sorry for a late update.
Thanks to @zeo I found the backup battery and replaced it, as you said @pgh-team all parameters were lost but I managed to type them in by hand again, so the machine is working again.
I did unfortunately get a new problem a couple of days ago, when trying to insert a new tool the hydraulic pump won't start when I'm trying to open the toolholder?
If I press the button on the relay (3RC2, if I remember correct) the pump runs (and builds up enough pressure to open the toolholder). Not sure why it doesn't start/run when I press the "open toolholder" on the RCU? I get no alarm or error messages.
Dear MahoMachinist,
There also should be a Tool- P/B on the main panel, does this one work ? Check with wiring diagram, does the CNC- O/P come ? Check wiring. Again check Machine constants, especially from 1000 to 30000.
Regards,
PGH-Team
Hi,
MahoMachinist
I just read this - i'm sure problem solved or let me know if still needed.
Take a look at my used Maho goodies. I know you're Sweden but it may be worth the boat ride for my Maho Dviding ead - it is new.
NC control Maho dividing head, been in dry storage - As far as I know it is controlled by B axis drive. Disconnect the rotating table and connect the dividing head .
I also have a Maho MH1200C - 532 control with extended keyboard - Rotating head M53,M54 vertical to horizontal and an NC control rotating vertical head +- 90 deg. - Got this form a friend for northern cal. was a working machine prior to moving it . It will need tinkering.
- i have experience with these machines as well. I have other maho machines -
Szia, elnézést a késői frissítésért.
@zeo-nek köszönhetően megtaláltam a tartalék akkumulátort és kicseréltem, ahogy mondtad @pgh-team, minden paraméter elveszett, de sikerült beírnom őket ismét kéz, így a gép újra működik.
Sajnos pár napja új problémám támadt, amikor új szerszámot próbálok behelyezni, a hidraulika szivattyú nem indul el, amikor megpróbálom kinyitni a szerszámtartót?
Ha megnyomom a relé gombját (3RC2, ha jól emlékszem) a szivattyú jár (és elég nyomást termel a szerszámtartó kinyitásához). Nem biztos benne, hogy miért nem indul el/fut, amikor megnyomom a "nyílt szerszámtartót" az RCU-n? Nem kapok riasztást vagy hibaüzenetet.
Üdvözöljük!
Nálunk is hasonló gond van a marógéppel, el tudnád küldeni a gépállandót valamilyen formátumban? Txt vagy hasonló formátum? Nagyra értékelném. Kösz
Üdvözöljük!
Hello Richárd,
My machine is a 3-axis Deckel Maho MH600E with toolchanger:
N0C 1
N1C 6
N2C 768
N3C 0
N4C 1
N5C 1
N7C 0
N10C 3
N11C 0
N16C 5
N17C 5
N18C 1
N19C 0
N20C 0
N21C 1
N23C 0
N27C 99
N28C 20
N29C 1
N31C 0
N32C 0
N34C 0
N38C 1
N42C 0
N43C 0
N44C 0
N45C 1
N46C 0
N47C 0
N48C 0
N51C 1
N70C 1
N77C 0
N78C 1
N80C 0
N81C 0
N82C 99
N83C 99
N85C 200
N86C 1
N91C 0
N93C 20
N100C 1
N102C 1
N103C 88
N105C 1
N107C 2
N108C 89
N110C 1
N112C 3
N113C 90
N131C 2
N132C 0
N133C 15000
N135C 1000
N136C 1000
N137C 100
N251C 15645
N252C 129894
N253C 1
N254C 1
N255C 933117
N256C 281545
N257C 0
N258C 0
N259C 0
N260C 289175
N261C 903039
N262C 162158
N263C 1
N264C 1
N265C 0
N266C 171723
N269C 0
N270C 1
N271C 0
N277C 0
N278C 636235
N279C 0
N280C 0
N281C 0
N282C 0
N283C 0
N284C 0
N285C 0
N286C 0
N287C 0
N288C 0
N289C 0
N290C 0
N291C 0
N292C 0
N293C 0
N294C 0
N295C 0
N296C 0
N297C 0
N705C 3
N706C 3
N707C 71
N710C 10
N711C 44
N712C 2
N714C 2
N715C 6
N719C 1
N720C 83
N723C 0
N724C 0
N727C 10
N728C 0
N740C 60000
N741C 20000
N744C 2
N745C 150
N746C 0
N747C 120
N748C 80
N770C 2
N771C 0
N772C 1
N773C 1
N774C 0
N780C 1
N781C 0
N782C 1
N783C 0
N790C 0
N797C 1
N798C 0
N799C 1
N840C 0
N841C 1
N842C 0
N843C 140000
N844C 5000
N845C 50000
N847C 0
N848C 5000
N850C 1
N851C 2
N855C 0
N860C 0
N861C 0
N862C 0
N863C 0
N864C 0
N865C 0
N866C 0
N867C 0
N868C 0
N869C 0
N900C 1
N901C 9600
N903C 1
N904C 30
N905C 1
N906C 1
N907C 0
N908C 0
N910C 1
N911C 2400
N913C 1
N914C 30
N915C 1
N916C 1
N917C 0
N918C 0
N920C 1
N921C 300
N923C 1
N924C 30
N925C 1
N926C 1
N927C 0
N928C 1
N930C 1
N931C 9600
N932C 1
N933C 5
N934C 3
N935C 0
N936C 0
N1000C 6
N1001C 0
N1002C 0
N1003C 0
N1004C 0
N1005C 60
N1006C 23
N1007C 80
N1008C 0
N1009C 0
N1010C 0
N1011C 0
N1012C 0
N1013C 0
N1014C 0
N1015C 30
N1016C 15
N1017C 0
N1018C 8
N1019C 8
N1020C 8
N1021C 8
N1022C 0
N1023C 0
N1024C 10
N1025C 0
N1026C 0
N1027C 0
N1028C 0
N1029C 0
N1030C 0
N1031C 0
N1032C 0
N1033C 0
N1034C 0
N1035C 1
N1036C 0
N1037C 0
N1038C 0
N1039C 0
N1040C 0
N1041C 0
N1042C 0
N1043C 0
N1044C 0
N1045C 0
N1046C 0
N1047C 0
N1048C 0
N1049C 0
N1052C 0
N1060C 0
N1061C 1000
N1070C 0
N1071C 0
N1072C 0
N1073C 0
N1074C 0
N1075C 0
N1076C 0
N1077C 0
N1078C 0
N1079C 0
N1086C 0
N1087C 10
N1090C 1750
N1091C 280
N1092C 140
N1093C 50
N1094C 50
N1100C 30
N1101C 240
N1102C 4
N1103C 30
N1104C 0
N1105C 8
N1106C 80
N1107C 0
N1108C 0
N1109C 0
N1110C 4
N1111C 3
N1112C 0
N1113C 0
N1114C 0
N1115C 0
N1116C 0
N1117C 0
N1118C 0
N1119C 0
N1120C 0
N1121C 0
N1122C 1
N1123C 0
N1124C 0
N1125C 1
N1126C 0
N1127C 0
N1128C 0
N1129C 0
N1130C 0
N1131C 0
N1132C 0
N1133C 0
N1134C 0
N1135C 0
N1136C 0
N1137C 0
N1138C 0
N1139C 0
N1140C 0
N1141C 0
N1142C 0
N1143C 0
N1144C 0
N1145C 0
N1146C 0
N1147C 12
N1148C 13
N1149C 0
N1200C- 600000
N1201C 26
N1250C- 450000
N1251C 14
N1300C- 450000
N1301C- 4
N2400C 4
N2401C 2
N2407C 10
N2412C 140
N2414C 171859
N2420C 4096
N2422C 360000
N2423C 1
N2424C 1
N2426C 3
N2427C 0
N2470C 300
N2472C 500
N2473C 0
N2474C 0
N2475C 0
N2476C 8013
N2477C 25
N2478C 10
N2479C 10
N2480C 10
N2481C 3000
N2482C 50
N2483C 80
N2486C 6
N2487C 50
N2488C 0
N2489C 50
N2490C 30
N2491C 746
N2492C 6
N2500C 50
N2502C 500
N2503C 0
N2504C 0
N2505C 0
N2506C 8927
N2507C 25
N2508C 20
N2509C 20
N2510C 20
N2511C 2000
N2512C 100
N2513C 50
N2516C 6
N2517C 50
N2518C 0
N2519C 50
N2520C 30
N2521C 5000
N2522C 6
N2530C 0
N2532C 0
N2533C 0
N2534C 0
N2535C 0
N2536C 0
N2537C 0
N2538C 0
N2539C 0
N2540C 0
N2541C 0
N2542C 0
N2543C 0
N2546C 0
N2547C 0
N2548C 0
N2549C 0
N2550C 2
N2551C 0
N2552C 6
N2560C 0
N2562C 0
N2563C 0
N2564C 0
N2565C 0
N2566C 0
N2567C 0
N2568C 0
N2869C 0
N2570C 0
N2571C 0
N2572C 0
N2573C 0
N2576C 0
N2577C 0
N2578C 0
N2579C 0
N2580C 2
N2581C 0
N2582C 6
N2590C 2
N2591C 2
N2592C 1
N2593C 20
N2594C 5
N2595C 10
N2596C 19
N2597C 10
N2598C 30
N2599C 40
N2600C 0
N2800C 0
N2900C 0
N3000C 0
N3100C 1
N3101C 0
N3103C 60000
N3106C 20000
N3107C 20000
N3110C- 1
N3111C 0
N3112C 6000
N3114C- 600
N3115C 0
N3116C 1
N3117C 10000
N3118C 601100
N3119C 100
N3120C 1
N3122C 1
N3123C 1
N3124C- 1
N3126C 3
N3127C 0
N3128C 0
N3135C 0
N3136C 0
N3137C 1
N3145C 590000
N3146C 590000
N3147C 0
N3148C 0
N3149C 0
N3150C 0
N3151C 0
N3152C 0
N3153C 0
N3154C 0
N3155C 0
N3156C 0
N3157C 0
N3170C 629
N3172C 0
N3173C 6288
N3174C 88
N3175C 0
N3176C 10000
N3177C 0
N3178C 10
N3179C 10
N3180C 5
N3181C 500
N3182C 100
N3183C 50
N3186C 6
N3187C 220
N3188C 0
N3189C 220
N3190C 30
N3192C 6
N3193C 2
N3194C 8
N3200C 3
N3201C 0
N3203C 60000
N3206C 20000
N3607C 20000
N3210C 1
N3211C 0
N3212C 6000
N3214C 450600
N3215C 0
N3216C 1
N3217C 10000
N3218C- 100
N3219C- 451100
N3220C 1
N3222C 1
N3223C- 1
N3224C 1
N3226C 3
N3227C 0
N3228C 0
N3235C 0
N3236C 0
N3237C 1
N3245C- 42750
N3246C- 41950
N3247C 0
N3248C 0
N3249C 0
N3250C 0
N3251C 0
N3252C 0
N3253C 0
N3254C 0
N3255C 0
N3256C 0
N3257C 0
N3270C 629
N3272C 0
N3273C 6288
N3274C 88
N3275C 0
N3276C 10000
N3277C 0
N3278C 10
N3279C 10
N3280C 5
N3281C 500
N3282C 100
N3283C 50
N3286C 6
N3287C 220
N3288C 0
N3289C 220
N3290C 30
N3292C 6
N3293C 2
N3294C 49
N3300C 2
N3301C 0
N3303C 60000
N3306C 20000
N3307C 20000
N3310C 1
N3311C 0
N3312C 6000
N3314C 450600
N3315C 0
N3316C 1
N3317C 10000
N3318C- 100
N3319C- 451100
N3320C 1
N3322C 1
N3323C 1
N3324C 1
N3326C 3
N3327C 0
N3328C 0
N3335C 0
N3336C 0
N3337C 1
N3345C- 4000
N3346C- 4000
N3347C- 4000
N3348C 0
N3349C 0
N3350C 0
N3351C 0
N3352C 0
N3353C 0
N3354C 0
N3355C 0
N3356C 0
N3357C 0
N3370C 629
N3372C 0
N3373C 6288
N3374C 88
N3375C 0
N3376C 10000
N3377C 0
N3378C 10
N3379C 10
N3380C 5
N3381C 500
N3382C 100
N3383C 50
N3386C 6
N3387C 220
N3388C 0
N3389C 220
N3390C 30
N3392C 6
N3393C 2
N3394C 49
:cheers:
