Oh man, they really handed you a flaming football, didn't they!
What grade of aluminum bronze?
These materials do not drill well in my experience.
The secret is to keep the drill very very sharp and never ever EVER let the job get hot.
Depending on the grade, it'll do all kinds of weird shit, some grades work harden in a heartbeat, some eat drills for lunch, some contract around the drilled hole and grab the drill twisting it off instantly.
Some warp like noodles if you overstress them, especially with heat, but also when you remove material from them.
If HSS is going to be your drill material, I hope you have a drill grinder and a bunch of drills you can rotate between.
I have never found a grade that is "easy"
I have found 954 to be the easiest grade for me to work with, but I have the most experience with that grade.
623 and 624 are also not too bad.
The nickel bearing aluminum bronzes are pretty bitchy to drill in my experience.
So are the Toughmet alloys.
I've done better with carbide drills than with HSS.
Those who drill it routinely seem mostly to use carbide through coolant drills with high pressure coolant, and push them pretty briskly to keep from work hardening the bronze.
Cheers
Marcus
www.implant-mechanix.com
www.vancouverwireedm.com
