Degreaser recommendations
MC Parts Kid
Aug 27, 2014
Hoboken NJ
Hi all, can someone here make a suggestion for machine degreasing. We suffered a major fire on 12/20 and have since move all the machines into new digs but they are filthy. I figure that this is the time to maintain and clean all of them. I've already figured out that lacquer thinner is not the answer, and that Simple Green stuff can't clean my beagles butt not along a lathe. Thanks in advance, Bob L
Marty Feldman
Feb 21, 2005
Owl's Head, Maine
Zep - industrial grade - works well, but as with all such products test it on an inconspicuous patch in back of the machine to be sure that you are not using it at a strength & duration that removes everything.
-Marty-
Big B
Jun 26, 2009
Michigan, USA
I've had good luck with Gunk foamy engine degreaser. There's a company called Beaver products that also sells foaming degreaser in bulk and applicators for it, depending on how much of a mess you have.
Jan 15, 2005
The Netherlands
There are dedicated degreasers for items that have been in or near a fire
I used it a lott because it also worked well as a general degreaser and I had acces to it
Ask with a compagny that does clean ups after a fire
Peter
MC Parts Kid
Aug 27, 2014
Hoboken NJ
Let me explain the fire. We didn't burn. There was an explosion in the building behind us which blew out our windows and set off the sprinklers. The sprinklers ran for three weeks because of two uncharted water mains. All our cnc's total loss. Were just talking plain dirt and grease here. I figure if I clean them up it will pick up the mood around here. If ya got time, Google 38 Jackson Street fire Hoboken, NJ. Bob L
MC Parts Kid
Aug 27, 2014
Hoboken NJ
No fire damage, just light surface rust that emery cloth and 30wt will solve. No lighting. A bunch of third worlds had a vape distributing in the building with 50-gallon drums of shit that didn't belong in the building. Two girls that were living there illegally were killed instantly. I used to teach has-mat. Those vapors are heavier than air and hover at the floor level. All it took was for one of these chicks to light a joint at midnight and throw a match down and the rest was history.
dalmatiangirl61
Jan 31, 2011
BFE Nevada/San Marcos Tx
Ben
Apr 3, 2001
Boones Mill, Va
For light rust, usually use a razor blade and the extra fine scotchbrite pad with mineral spirits (or paint thinner).
For grease and oil I use Purple Power full strength. It can be had at most auto supply houses and I think I have bought it at Walmart. I bought a spray bottle to spray it on, I usually buy it by the gallon.
1yesca
Jun 1, 2004
Huh? Your point?
my point go google 38 Jackson Street fire Hoboken, NJ. as the op suggested and see what some of the tenets had to say about the fire
the building had been sold and the new owners wanted to something new with the land . like they say follow on money . its like the
three ol guys from up north are down in Miami for the winter the one as telling the other two how one of his vacant buildings had Burt
down then one of the others tells how one of his building had major water damage do to a fire sprinkler mishap the last one tell how a
tornado destroyed one of his buildings the first guy ask how do you cause a tornado so that's my point
wood2steel
May 17, 2013
georgia
Bob, I agree with Marty. I use several gallon a month of Zep Industrial Purple Degreaser both full strength and diluted to clean machines going through rehab. Just test the waters as to how strong a mixture you need. It will instantly knock the light grease and crud off. Then do your normal rust protection coating and you're all set.
52 Ford
May 20, 2021
that totally sucks sad thing is you never know were Jewish lighting is going to strike
You either got your terminology mixed up or you're implying "something" :D
Jewish lightning refers to insurance fraud. I'm sure you know that.
52 Ford
May 20, 2021
A few of my friends worked for a company that did commercial kitchen exhaust cleaning. Cleaning the exhaust hoods and duct work.
I believe they used Purple Power as a degreaser - I'll have to ask. Whatever it was, it was VERY strong and VERY effective.
I'll try to remember to ask them today.
Screwmachine
Mar 8, 2001
Switzerland
Just watch with some of these they're a strong alkaline and will f-up aluminum and at least degloss paint (or strip it in some cases). Used to use a lot of Castrol Super Clean which I guess Purple Power is a copy of. Got the bright idea to wash my whole car with super clean one day (I was 18, and had gallons of it and less brains), didn't look so good after haha, but it was _clean_.
For painted machine surfaces I like mineral spirits and fine steel wool, or scrubby pads for teflon pans.
For flat bare metal agree with above, razor scraper is great for the bulk work.
