Trboatworks
- Oct 23, 2010
- Maryland- USA
Hello all.
I am building a set of Delrin bending shoes to be used on bright dipped anodized pipe for a hydraulic bender.
I am bending 7" CLR into 1-1/2" 6463 bright dipped anodized SCH 40 pipe.
What I have is a 120 degree Delrin shoe with 1/2" 6061 plate bolted on each side to hold the wall from flattening.
The depth of groove milled for the pipe is just over radius of pipe.
I have two shoes built.
The first is a 9" CLR and is working fine.
The 7" shoe is folding the pipe rather than bending.
So....
Where to go with this to get this done.
The first thing I will do is deepen the groove to get more than radius held on pipe wall with the hope of keeping the pipe from springing out of the shoe.
I am using air over hydraulic and a small compressor so I have to wait for the compressor to catch up as I do the bends.
One thought is the pipe is work hardening and by waiting on the compressor I am not getting this done in one throw so fighting the material.
The other is I am not setting the outboard turning rollers at the correct distance from shoe but have played with close in and further out with same result.
Other thoughts?
Thanks all
What I have :
So....
Other thoughts?
Thanks all
What I have :
