I'm new to abrasive machining. I bought a White-Sundstrand RG8 that came from a mold shop being used for truing cast iron molded castings. My intended use is to prep hot-rolled mild steel parts for welding. Would like advice on the proper fluid to use. I was planning to use the same oil-water emulsion that I use in the horizontal saws. While draining the old pump fluid, it looked like hydraulic fluid to me. What is the proper fluid for my application?
Thanks in advance for your advice.
Charles Vernon
Charles Vernon
