DN Solutions SVM 4100
Miller846
Oct 23, 2022
Good Afternoon, Just curious if anyone has any experience with the new Doosan SVM 4100? What are the differences between the SVM and DNM, besides weight/rigidity? Looking for a machine to mainly cut aluminum parts fast and feel that the SVM might be a good fit but I also am looking for a quality machine that will last a long time with little to no issues. I know the SVM was built to directly compete with the VF2SS, just wondering if doosan cut corners in quality to do it. Thanks for your input!
DouglasJRizzo
Jun 7, 2011
Ramsey, NJ.
I used to work for Doosan.
The SVM is every bit as high quality build as the DNM. It's mostly for aluminum/plastics.
It's a shade lighter and maybe not as robust but fully capable for its intended use. No corners were cut, per se, but it's specifically built for aluminum and plastics cutting. It's built with a 30/40 year lifespan in mind.
If you're going to cut a mix of metals with stainless and steels thrown in, go for the DNM. I've seen them chow on stainless, and tough steels all day and shrug it off.
LockNut
Jan 6, 2007
Bergen County
I usually don't comment on these opinion type request posts since I work for DN Solutions. I am currently putting an SVM4100 and an SVM5100 through it's paces and I am impressed. We don't cut corners to compete with Haas, we don't have to. These machines are geared towards Aluminum cutting at high speed but I have also cut 42Rc mold steel on the SVM4100 and it didn't even flinch. The attached image was a test cut result in Aluminum. This was finished at 12K RPM and 150 IPM.
matthewlee
Jan 7, 2012
st louis
I have a SVM4100 and love it so far. It came down to this machine and a Brother and I went for 40 taper and more Z travel.
No expereince with the DNM series, so cant really offer anything there. The SVM did fit in a 8' high door and the DNM wouldnt.
Miller846
Oct 23, 2022
Wow, a picture is definitely worth a thousand words. Very impressive finish! Is DN Solutions coming out with a SVM 5100 as well? Sounds like I will probably opt for the SVM over the DNM as I do 99% Aluminum/copper/plastics and could use the money saved on tooling. When I take a finish pass at 150 IPM on my haas, it definitely does not look like that, even with high end coolant, endmills, etc.
LockNut
Jan 6, 2007
Bergen County
Yes, we have an SVM5100L. The L version has a longer X axis travel at almost 50 inches. Same spindle and same tuning for high speed Aluminum cutting.
Milland
Jul 6, 2006
Hillsboro, New Hampshire
Any sense as to the saddle stiffness when the table is to one side? When my VF-5 is loaded there's a noticeable rock with the table extended, would like a better option for long parts.
LockNut
Jan 6, 2007
Bergen County
Milland, Our Y Axis saddles are very wide, about 88" on the SVM5100L. There is only about 6" of overhang at the extreme limits of the X axis. There should be no sag. I cut an Aluminum part that was 24" long, did a waterline toolpath on a 5 degree tapered wall. After CMM, there was no more than .0005" error at any point on the form. This was cut at 138IPM. All other SVM models are similar proportions depending on the model. The tables are fully supported along the entire length of the X axis.
Paul
Orange Vise
Feb 10, 2012
California
I thought the DNM was already in VF2SS territory?
Fast aluminum machining is Brother Speedio territory.
Miller846
Oct 23, 2022
The DNM seems to be equivalent in price to an optioned up haas where as the SVM appears to have a few less options and comes in slightly cheaper than a similarly optioned haas. Both appear to be great machines from what I’ve seen.
Rick_H
Jan 26, 2013
uk - midlands
What does a base SVM come with - Is a swarf conveyor / auger and TSC optional?
Its a machine I would be looking at to replace an ageing VMC we have but would want the above and control options to be able to handle some 3d machining.
This would go up against us getting another long bed robodrill for us but with this machine being a bit more flexible - it would be interesting to see how pricing stacks up.
LockNut
Jan 6, 2007
Bergen County
Rick_H, here is what comes standard. Base price is 74K. Note it does come with AICCII and that also includes Nano Smoothing (G5.1 Q3). The avove photo I posted was with a stock machine.
Main Features
  • FANUC 0i-Plus control with iHMi touch screen interface
  • Meehanite cast iron bed
  • High precision, direct coupled spindle design with (5.5 / 18.5 kW \ 7.375 / 25 hp motor, 12,000 rpm)
  • Spindle oil chiller
  • Spindle orientation, load meter, override and rigid tapping
  • Cam Type, Double Arm ATC with shutter door (30 tools)
  • Large ball type linear guides (X - 35 mm \ 1.378", Y - 35 mm \ 1.378", Z - 35 mm \ 1.378")
  • Servo motors mounted directly to the oversized and pre-tensioned ball screws (X - 32 mm \ 1.26", Y - 32 mm \ 1.26", Z - 32 mm \ 1.26")
  • Fast rapid traverse rate (X - 36 m/min \ 1,417 ipm, Y - 36 m/min \ 1,417 ipm, Z - 36 m/min \ 1,417 ipm)
  • AICC II (200 block look ahead) + 1 gig data server
  • Renishaw probe ready (OMI-2T optical receiver and GUI software only)
  • Doosan Tool Load Monitoring and Adaptive Feedrate Control
  • Doosan Smart Thermal Monitoring (Software algorithm based thermal compensation system)
  • Standard Equipment and Warranty
  • 20 bar (230 psi) Through spindle coolant, Air through spindle
  • Flood coolant with large separate coolant tank (240 liter \ 63 gallon)
  • Bed flushing coolant for chip disposal
  • Full enclosure splash guard
  • Telescopic covers
  • Eco friendly grease lubrication with 1 cartridge pre-installed on the machine
  • Portable manual pulse generator
  • Program and data protection key
  • Work light and 3 color tower signal light
  • Two-year machine parts warranty, one-year labor warranty. See warranty pages for details.
  • Two-year control warranty: Parts and Labor
  • Doosan instruction, operation, parts list and electrical drawing manuals in hardcopy format
  • FANUC manuals provided on USB drive (Hardcopy available for purchase, contact parts department)
GiroDyno
Apr 19, 2021
PNW
That price is for the 4100 or 5100?
What does it cost to add work/tool probes and a conveyor?
DouglasJRizzo
Jun 7, 2011
Ramsey, NJ.
Correct. The DNM is a high line machine.
