.I was told that a micrometer didn't need to be lubricated because oil that is too thick can cause it to tighten up. If that's true, how do prevent the screw from wearing out?
as a apprentice over 40 years ago i used take my mic apart into separate pieces and reassemble dozens of times a day.
i probably dissembled my mic about 1000 to 2000 times before I got bored doing it. most mics have a split nut that can
be adjusted looser for oil clearance but if oil gone screw can be too loose in nut (backlash)
when mic screw lubed with thin air tool oil the screw turns very very hard, harder than clutch can turn. cleaned oil off screw
and its back to normal. basically wiped as much oil off screw as i could with a rag. you can mix oil and mineral spirits
so when minerals spirits dry it leaves a very thin residue. or some use spindle oil (coolant) its a oil thats
water thin or almost as thin as minerals spirits. Starrett M1 spray oil is I believe oil mixed with minerals spirits.
if sprayed in ring gages it leaves little residue after it dries, sure theirs some but cannot see it or usually
feel it
......I have seen hundreds of mics over the years turning so hard overloading clutch, electrical contact cleaner
no residue type, spray on work it back and forth and mic back to normal with normal friction clutch
action. most shops I have worked at over the years carry it in the tool crib or can get it. its in most industrial
supply catalogs.
dampening grease Nye makes a kit of varying thickness is used on optical lenses so when lens points down lens
doesnt easy slide by gravity also gives a silky smooth sliding feel as apposed to feeling like parts rattling loose
in other parts. dampening grease can dry out over many years so what used to move easy becomes hard to turn.
when a drill press chuck is hard to turn, electrical contact cleaner will clean the dried grease and other stuff
out of it, spray and work it back and forth so it drip out off it. its not made (clearance wise) for thick oil
or thick grease. many precision parts are like that
For those who lube.
On the threads which means taking it apart or just on where it moves in and out of the body?
... My stepfather for instance, should not even be allowed to touch micrometers...![]()
"Hey, did you know these things make great little C clamps? You can really torque 'em down."
I'd honestly be more surprised if he didn't figure out a way to use it for a hammer... The man has very little finesse, very much brute force. Heart of gold though.
Notice
