Doosan DNM500 TSC delay
colton_m
Apr 16, 2015
Hi Everyone,
I have a situation with a Doosan DNM500 mill.
When the thru spindle coolant is commanded on there is a long delay before it actually gets to the tool and starts flowing. It generally varies between 4-10 seconds, but sometimes doesn't come on at all. We have fully cleaned the tank, intake filters, screens etc. I have checked all the hoses for obstructions and found nothing. The bag filter is brand new, the housing is spotless but still the issue persists.
I have narrowed it down to the pump itself, it is running instantly on an M07 command but takes a long time to build pressure if at all.
Has anyone encountered this before? Any suggestions or procedure to take the pump apart?
Thanks!
D Nelson
Jan 7, 2015
Missouri Ida
Sounds like you need a check valve in line. Sounds like it’s loosing its prime. When it starts flowing if you shut it off and emediately restart does it work then?
Don
