Doosan lynx wired correctly?
chip_maker
Jan 14, 2006
Moira, NY USA
I moved my 2014 lynx220lmsa and just got it wired back up.
Is there any way to tell if it's phased correctly or if I need to swap 2 wires around.
On the newer Haas mills there is a light in the electrical cabinet that will let you know if you wired right or not.
Does the Doosan have anything like this?
Figured I'd ask as I don't want to do any damage to the machine.
JonFinn
Apr 25, 2013
CA, USA
The control doesn't care, it only matters for the 3-phase motors. Just fire up a coolant pump for a few seconds and check the rotation. If it runs backwards, switch two of the phases and you are set.
huleo
Feb 12, 2014
UT
Ha, I don't gamble that way. Buy a phase rotation meter and you will never regret it. Running a hydro pump backwards might cause bad things. It is just an unneeded risk.
