Good day, have a Doosan TT1800SY multi-path machine running a fairly involved part requiring live adjustable angle heads, pinch turning, cross path work, bar fed, polar interpolation and synced multi axis cutting with inverse feed so on and so forth. My question is, since I'm using a generous amount of wait codes to keep things from running into each other and turrets bouncing from one spindle to the next. Is there a "proper" way to restart the machine in the middle of a process, after turning on Op Stop. Doing so causes the machine to wait for both flows to reach an M1. Starting back up at this point starts the machine out of sync due to the machine waiting for both systems to reach its M1 in its program. As a matter of fact, I believe trying to do this actually causes the machine to soft alarm warning about sync codes not be aligned or something along that effect.
Your input would be appreciated
