doubts about the bolt of the fgc-9
Bradock
Jun 6, 2022
hello my friends, I was looking at the pdf file of the construction of the bolt of the fgc-9, and I could not see the fitting for the cartridge (completely straight) and neither the extractor. Is something wrong or is it just like that?Screenshot_20220606-170132_OneDrive.jpg
Bradock
Jun 6, 2022
June 6th. Sorry buddy if this was a stupid question as i have never seen a bolt without the cartridge and extractor fitting. In the pdf file it says it's finished and there's no mention of what I believe it's missing. I'm just a hobbyist and I ask you to forgive me for my ignorance. If you want to help me I would appreciate it very much.
BoxcarPete
Nov 30, 2018
Michigan, USA
Sorry, it just looked like you might not have been serious with what looks like sloppy globs of weld hand sanded and pressed into a 3D printed plastic housing asking if it's supposed to look that way. I didn't fully understand what the FGC-9 is supposed to be.
Took a quick look at the design and it does in fact look flat except for the hole for the firing pin. Could it be that the pressure and/or recoil is supposed to cause the spent case to exit the chamber?
Bradock
Jun 6, 2022
I'm also asking myself the same question. I've never seen a bolt without a cartridge slot before. I'm also asking myself the same question. I've never seen a bolt without a cartridge slot before. The most curious thing is that this gun was designed to use a glock barrel, and this in turn keeps the cartridge out of the chamber. This bolt cannot be finished.images (2).jpeg
Bradock
Jun 6, 2022
Hi my friend, I got the answer from an Fgc-9 builder. He told me that the bolt doesn't have a slot for the cartridge and extractor, because the cartridge is expelled due to the burning pressure and is ejected by a paddle ejector. I believed that the gap between the cartridge and the slide would be a problem, but this issue is detailed in the project and there seems to be no problem.Screenshot_20220607-085532_Drive.jpg
Amsel
Jun 8, 2022
It will work - as long as you do not have a failed cartridge, in which case you have to extract it manually by inserting some rod from the muzzle end.
I find the whole FGC to be a rather peculiar mix of ingenuity (the ECM-manufactured barrel), kind of sloppiness (absence of the extractor) and outright stupidity (use of PLA which melts quite easily, print direction for some stressed parts etc.).
