AlfaGTA
- Dec 13, 2002
- Benicia California USA
Sure this has nothing to bear on this discussion...but i see two major areas to consider in the purchase of any machine or accessory.
First off is it capable of doing the job. Will it provide the necessary accuracy, ease of use and features needed for the range of work it is intended to support....
Second and in my book easily as important....
What is the user interface like...Noe some would assume that i am referring to the readout and how you enter data and the like, and yes this enters into this , but for me it goes much further!
I am interested in the package...How is the product, in this case a DRO housed....how are the scales mounted and enclosed...can you buy spare parts like seals for the reader heads etc.
Not a mystery i guess that i am a "solid" advocate and end user of the Heidenhain products...
My choice is based on the reputation of their products, and equally the feel, fit and finish of the entire package.....
I am dead set against any keyboard interface that uses "membrane" style keys.....I hate, hate, hate, hate that style if user interface.....Gotta have real hard , stand proud buttons that your fingers
can feel....
Further The HH DRO's have a real die cast aluminum housing for the display...Not folded sheet metal or injection molded crap.....
Also to note, the HH DRO have select able axis depth compensation ...What that means is if you select the "Y" axis for your length comp, then your "X" and "Z" become the positioning moves, and things like
scaling and bolt circles will be orientated for the horizontal axis....a nice feature for any mill having both a horizontal and vertical axis....
Not sure if this is a feature for other DRO's.....
Initial cost is certainly a factor....But becomes less os if considered over the potential life span of the machine....Don't want to buy cheap only to hate using it every day....
As to the future , perhaps one day getting an FP2.....might consider buying the scales longer than needed for your current FP1 so that the DRO could be transferred should an FP2 come available.
Personally i would not go this route, but its an option you should consider....
Cheers Ross
can feel....
Cheers Ross
