arbor diameter to allow more types of wheels.Merged the old posts from the unrelated thread here.
Explain a little better what you're trying to do as regards the ⅜" to ½" adapters and you'll get better answers.
and cereal box stock is good/OK .I've used manila folder to make 'em before.
The intention/purpose of the blotter is to allow high facets of the abrasive stones/grits to have a place to go rather than pushing into the structure of the wheel where they might act like a chisel to crack the wheel.
The word blotter suggests that it will soak up those high grit points.
(X) The likes of computer copy paper is too thin to do any blotting (soaking up the high points)...(X*).
I stick a blotter on the wheel with a few dabs of Elmer's glue because that can be soaked off. Norton likely used the sam /like glue because Norton blotters could be soaked off. Reusing an old blotter I put the notation facing the wheel if it is going on a not the same grit and hardness wheel.
The blotter should be a size that will stop the flange from touching the wheel ..and a little larger/exposed so the operator can see that there is a blotter in place.
*X..->My handy note system. when you mark or see an (X) on a part or on a print You know or suspect there is something wrong. An (X) with an initial denotes who added the (X)
I would Mark "(X) JB" on something that I saw or suspected some problem, perhaps an X and an arrow pointing to a defect, perhaps an X on apart where the size is right on the limit so the inspector is sure to notice.
Hav'nt found any good steel 3/8" x 1/2" bushings yet.
QT Eric...(I always write "NFG" where there's a problem).. but if you have a big bruiser in that shop you could end up with a sour nose.
Sure I have a lathe! But my time is worth more than $10 P/hrYup, cereal box is good, and cardboard from the back of a notepad too. I always write "NFG" where there's a problem rather than an X,
You don't have a lathe?
I could make a screw driver but I would rather buy one.
Notice
