Hunfab Industrie
- Feb 19, 2022
I recently purchased a Clausing Kondia fv1 with a dynapath 20 motion controller. I have it plugged in via 3-phase converter. Each leg is at 120v. When i go to turn on the machine the screen does not turn on and controlls do not work.
PIC lights are Run: (Green), RAM Test: (Red),WDT Fail: (Red)
Proc Run: (Green), Param Int: (Blank)
Panel on: (Blank), Proc WDT Fail: (Red)
I've read somewhere I need to swap the motherboard wire to something other than the 3rd leg of the phase converter. I am not sure what/where to go about that if that is the case.
Also I accidentally shorted the power supply frying 2 resistors that i have soldered in new ones. This issue happened before/after with no change. When the psu fried it was still showing the same lights so nothing turned off.
