So I'm in the middle of repairing the cnc aspect of the machine, it's an eagle 54x10 with an anilam crusader m controller ,all of the pcbs are out for repair , inspection. I've been using the mill manually for a few weeks and last night it wouldn't turn back on. The front of the machine has a reset switch , there is also a cutoff switch on the monitor itself. There is no power getting to the switch or the magnetic contactor in the back of the machine. If I push it in manually the motor will run. I understand that the switches either open or close the electrical circuit, there are several transformers in the box. I was also thinking maybe there were travel limit switches ? Any help is appreciated
Would be helpful
trim.1FD7103B-DE2C-43D9-A097-C4584BF0990A.MOV
Would be helpful
