I picked up this early plain bearing hardinge Cataract the other day. Has a 5c spindle with taper lock chuck. Has the slot on the back of the bed for a thread chaser, but no chasing parts. Also has the gear on the spindle for thread cutting, the original change gear bracket, and what I believe is the original telescoping power feed rod. Someone has modified a right angle gear box and motor to make it power feed although I haven't tested it to see if it operates.
Does anyone know how to disassemble the headstock? I'd like to clean and re-felt it before trying to run the spindle.
Any more info you could provide would be great, Im new to the cataracts.
Edit: I just learned the transmission is a borg Warner T92 3 speed transmission that was used in small tractors and crosley cars.
