Edgecam post
JASE1
Jul 26, 2018
I’m looking for a Edgecam post for a
Mazak Integrex I400. Can any 1 point me in the right direction ?
Beardo
Feb 1, 2022
Edgecam has one of the most robust, user friendly post writers on the CAM market. All you have to do is start a new Code Wizard document. Once you select the lath discipline, you select your machines axis capabilities, specifying the units, default parametric graphics, and the Adaptive Intergrex template. It will prompt you on your machine specifics, once finished you have a post that is at least 85% of the way there. You can massage your output through the Code Constructor section, allowing you to modify every segment of a program, like toolchange, rapid movement to and away from toolchange, rapids, drill cycles, etc.,.
If you need assistance, Edgecam has great forums, and of course your local Hexagon support rep.
