SeymourDumore
- Aug 2, 2005
- CT
Guys, has anyone found a good alternative to the piece of junk air-over-water pumps typically supplied with the Chinese ( or Taiwan ) made
machines?
For christ's sake, this is the 3rd pump I am struggling with!
Seems like every one dies for the same reason: the pump head is an Aluminum casting which is only Chinadized.
First, as the guts corrode, the white shiit that AL turns into is plugging up the inside.
That would be almost OK as it can be cleaned, but when the frigging corrosion occurs on the seats and bores, they become non-functional.
Is there some other alternative out there, perhaps something like a paint sprayer pump or similar?
Else, Is there a non-Chinese garbage air-over-water pump that will last?
machines?
