Holescreek
- Aug 27, 2004
- Centerville,OH
Interesting! I knew about seal distortion (with seal in bore) causing the retraction of the piston, but I wasn't aware of the angle at the bottom of the seal groove. Is that a common feature in all SiB calipers? And presumably the angle is oriented to make the seal tighter at the front (towards the disk) side? Or is it the other way?
And for that matter, how do the seal on piston calipers retract? If anything, deformation of the seal should make things worse, right?
Did your company make complete caliper assemblies, or just the pistons?
The seal groove is tapered shallow at the front so when the pressure is released the rubber seal relaxes backwards pulling the piston back. The piston doesn't need to move a great distance in retraction, just enough to take the pressure off of the brake pads. The test for this is called drag torque. The customer specs determine the maximum amount of residual drag torque allowed after cycling the caliper at a specified pressure.
The company makes complete OEM disc brake calipers, electronic parking brake calipers and ESC (electronic stability control) units.
To the OP: Sanding pistons is a really bad idea in my opinion. I understand that you did what you felt was necessary at the moment. Piston diameter and surface finish is critical to caliper function. The caliper seal only rides in a small area of the piston but this area changes over time as the pads wear. You might be in a "good area" of the piston right now (but maybe not) but when the pads wear another 5-6 mm the seal will be riding that much lower on the piston too. Fluid seepage past the caliper seal can build up until it fills the piston boot before you even start to notice it on the casting so keep an eye on the fluid level in your brake reservoir.
