mihaihotca
- Feb 21, 2023
Hi there, I would be curious if I can find someone that has done a conversion or would know i theory if it would be suitable to replace a bad forklift battery with one from an EV.
The forklift is rather old and used a 48v 400ah lead acid battery. I’ve had it lying around for some time and now I want to either make it run or scrap it. Replacing the battery pack is too expensive and it’s still the same technology of lead acid, I would maybe use it for the shop around 1-2 times per month to unload light stuff so not too feasable to invest in the traditional battery. I saw that new models are using lithium tehnology and I had to question myself if I can use a used battery pack from an electric vehicle, they have a fair price and at least they have better characteristic than lead acid for life time/weight etc.
So my question is would this be a simple job as findig an 48v battery pack and simply connecting it to the forklift? I understand that I would have to change the charger and I also know that the packs come with some battery system management on them.
