Electric pallet jack drops too fast?
richard newman
Jul 28, 2006
rochester, ny
My Yale MPB040E pallet jack drops WAY too fast with a load, bam!!! What could cause this? Fluid was low when I got it, topped it up, no change. Now I'm curious what actually determine the lowering speed, some sort of flow restrictor? Attaching parts diagram.
edit- changed pdf to jpeg
BT Fabrication
Nov 3, 2019
Ontario Canada
they all do that, its an electric solenoid thing. skid steers are the same way. this wasn't designed to reduce the return flow from the looks of it, normally you need a second solenoid to do it that has a small orafice to return to the tank.
Strostkovy
Oct 29, 2017
Looks single acting. If you want to reduce the lowering speed break the extend line on the lift cylinder and install a check valve and needle valve in parallel with eachother and in series with the line.
richard newman
Jul 28, 2006
rochester, ny
Thanks, this seems like it would certainly work
But I'm convinced something is wrong, with a load of just 1000 lbs it comes down so fast the floor shakes. Don't remember anything like it when I rented one years ago.
Strostkovy
Oct 29, 2017
It's not a closed system, there's a breather. The manual says to remove air by cycling up and down a few times.
There can still be air trapped under the piston that can't get out. You may have to tip the jack and then lower it for the air to make it to the breather.
DDoug
Oct 18, 2005
NW Pa
I'm not an idiot, I have worked on other forklifts, How many have you ?
Seeing how you only want to quote the manual to me, I'm done trying to help you.
richard newman
Jul 28, 2006
rochester, ny
Problem solved!
Took the solenoid/valve assembly out, and found what looked like a flow restrictor inside. Marked with a red arrow on the drawing. Hole was .080", made one with a .040", made a huge difference!
Thanks for all the suggestions. Sure glad I didn't have to turn the jack upside down to bleed the cylinder, but I don't understand how just raising and lowering a few times does that?
