Dave.Phillips
- May 20, 2023
Hello all!!
I can use some help with my next resurrection...
I just got this lathe and I'm needing some help with the thread size on the head and some ideas what changes this lathe had.
Ok what I know ... ( or I think I know lol )
1) The bed is a number 4 Elgin 32" with the optional tray. I'd presume 1920 time frame.
2) Compound looks like Elgin. I haven't found and Hardinge stamps yet!.
I'd HELP time please!!!
3) Headstock is stamped Hardinge .599 notice the uncommon noise thread and oilers. Now I understand someone probably installed the oilers however the fittings are factory. It also appears to take 4C collets.
4) Tailstock has matching numbers with the head ... I'm happy with that!!!! Tailstock is also a bit different being open Fram however I know they existed in some models and custom made lathes.
Like I mentioned I need some help with the Headstock thread size and you're best guesses what this lathe experienced.
My thoughts are this...
I believe this lathe was purchased as a complete lathe from Elgin sometime in the 20's. The Headstock and Tailstock were added as upgrades and or shop changes sometime in 30's maybe. Notice the stripped teeth in the back of Headstock indicates that this Headstock was used on another lathe that utilized the threading options from Hardinge we're the Elgin #4 bed I have doesn't support this option as it has no T-slot in the back of the ways. That's why I mentioned possible shop upgrade we're the gear stripped and the headstock and tailstock we're transferred to the older Elgin lathe that would essentially make it a Hardinge #5 lathe less the back T-slot and at 32" not 38".
Photos in next post
And thank you!!!!
Photos in next post
And thank you!!!!
