jim rozen
- Feb 26, 2004
- peekskill, NY
My advice: never run morse taper reamers under power.
I used a boring head, in the headstock, to get a center location in the ram, held stationary in the tailstock. The ram was then transferred to another, larger lathe, held in a 4-jaw chuck. The start bore was centered in the chuck, and the OD was adjusted to be sure it was parallel to the tool travel. Then the morse socket was rough bored using the compound adjusted as close as I could get it. Finish was with a MT reamer pushed by a center in the tailstock, turned by hand with a wrench, the headstock spindle locked.
