NC Rick
- Oct 7, 2007
- Asheville, NC
Hi folks,
I have what I am sure is a rookie question so I appreciate your understanding. We often need to enlarge holes that are either 10mm or threaded M10 but need to be 12mm. Often this happens one part at a time but more common is 6-10 pieces. I get good results using a stub length drill in the Bridgeport with vise stops and all the associated settings to make the drill run concentric with the existing hole. I need our technicians to be able to do this efficiently and need a nicely finished hole since the part is very “customer forward”. I have been screwing around with the drill press and get a good result with an undersized hole followed by a reamer when I changed to a better chuck than is shown. The problem with that is there are too many steps in preparation for doing the multiple operations. I was getting ready to order a 12mm taper shank drill and just close my eyes…. Accuracy isn’t as important as just a nice looking professional hole. I remember having used a drill designed for such a purpose (a core drill or “dreamer”?) but searching McMaster-Carr hasn’t turned up such a tool.
I attached a photo of the setup I am trying to use which is a light duty drill press with a floating vise. The chuck pictured is what is normally mounted but runs out too much causing some chatter starting the hole. I hope my question makes sense. Telling me I am dumb won’t be insulting since I know I’m not experienced in this kind of thing. I appreciate any guidance from you folks!
Rick
Rick
