Stirling
- Dec 11, 2013
- Alberta canada
Purchased a 2008 vf2-D this weekend with known issues. 123 Spindle Drive Fault, 993 Amplifier Short Circuit.
Owner had been quoted (sight unseen) a vector drive, regen unit, 30 amp and 45 amp servo drives.
machine has 200 hours on it, and hardly a scratch in the chip auger to prove it ("R and D" at a university)
I've taken a day and tested everything I can that Haas has listed throughout their literature and videos and have come up with no faults. I am not opposed to a tech coming or buying new parts, but I live 5 hours from a tech so service calls are very expensive! (10 hours driving and an overnight/meals charge) so multiple trips are not good.
is there any tips out there?
situation:
previous owner reported the problem started intermittently. he would turn it on and it would error, but in 30 min it would clear, then it would be an hour, then 2, then 5.. now it just stays alarmed
10,000 RPM spindle, has a wye/delta switching. looks good. wye engages on power up no indications of failure, haas lays out no tests beside eyes and nose for this.
no visual or smell indicators, cabinet looks absolutely new
with everything plugged in, it throws the errors 123 Spindle Drive Fault, 993 Amplifier Short Circuit.
if I disconnect the spindle motor leads the machine operates just fine but no spindle commands
this would lead me to the motor being at fault, but I have tested the motor and it passes all of the test haas lays out. cable passes too. I will have a friend with some fancy motor test gear run further tests this week
I have also done all the vector drive tests haas recommends. Regen tests good, servos all run fine with no errors (when motor is unplugged)
Im at a loss. is there something on the boards I can test? I have checked all connectors in cabinet and head, played around with unplugging different things to see if they flag errors (they did)
Thanks for any advice you may have
I have a little more time thank money, but we all know that time could be sales calls!! (whats the balance ? haha)
situation:
