Is anyone familiar with tear down to get to the quill return spring on this style of bolt pattern? I understand the procedure of using the 7/16 bolts as pushers after inserting the set screws in the two threaded larger bolt holes. I got this from an older manual, but the older style does not have the two other smaller threaded holes that I have the cap screws inserted in, in my pic. I assumed this was a later designed separate piece that was pushed off first, but no luck. Is that a locator pin in the center? The problem is that the “cover” has too small of holes to let the 7/16 bolt pass in to the threads. At first I thought there were tight fitting washers blocking the holes but doesn’t seem to be. Thanks in advance for any info.
