Ox
- Aug 27, 2002
- West Unity, Ohio
Chemetall Tech Clean 7610M
I have 1.75 totes available.
Basic washer fluid for ferrous and non-ferrous apps.
Does contain some R/P value for ferrous.
Listed as a use for vibratory finishers as well.
$750/tote
I have tech sheets for this product.
Chemetall Washer CleanPlus
I have 1.75 drums of this.
This is used to clean out the washer and system itself.
Progress Chemical - L393
I have 5.75+ drums of this stuff.
It is a legacy product that is almost identical to L590, and so there is no online listing.
L590 is just an updated version of this product, and the customer that had this was very happy with the product and just didn't want to try something new.
This is a washer fluid that is suitable for ferrous products, and has R/P components included.
Said to have 2-3 yr shelf life at least - unopened.
$175/drum
L-59 Parts Washer Compound
Progress Chemical - 1831 Concentrate
I have 1.5+ drums of this.
This is a corrosion remover and preventor.
Low hazard chemistry.
For use mostly in ultrasonic cleaner apps.
$100/drum (let's make a deal)
1831 Concentrate
Progress Chemical - 50R
I have two partial drums - 3/4 and 5/8
Basic Rust Preventative product
5-R Rust Inhibitor
Kyzen Chemical - Metalnox M6314
I have 1.75+ drums of this.
Parts washer soap suitable for 1 stage washers - safe for non- ferrous, but the engineer that I just talked to said that it does have short term R/P value for ferrous products. Low foaming.
Will sell for $150/drum
Metalnox: Metal Parts Cleaner, Metal Finishing Solvent, Cleaning Metal Parts | Kyzen
I have tech sheets.
Kyzen Chemical - CP90S
Aqueous Long Term Dry Film Corrosion Preventative
Can be used as a stand-alone post-process spray application, but can also be added to other products in a washer system for added R/P value.
Very long shelf life. Plaque says 5 yrs unopened, and you know that's conservative.
No online link to this product, but I have the tech sheets.
419-924-5616
I am Ox and I approve this h'yah post!
$750/tote
$175/drum
1831 Concentrate
5-R Rust Inhibitor
I have tech sheets.
419-924-5616
