Fanuc 15-t spindle RPM maxes out at 45 RPM No alarms
TM1
Jan 10, 2009
Oregon, USA
I have a mori lathe with a Fanuc 15-t controller. When I input a RPM in MDI say 1500 RPM, spindle only turn 45 RPM. I'm not getting any alarms on the machine or on the spindle drive. It has a Fanuc spindle drive A06B-6055-H422.
Same also happens when I use the manual button for turning spindle like in jog mode. It will max out at 40 some rpm. When I use revers and turn the spindle Pot it slows down and reverses, but only in revers.
I swapped out the control drive front board thinking it was the issue. Same issue.
Human
Jan 24, 2022
Bummer. Have you carried out a visual inspection of the drive board/components? See if anything is overheating or worst, magic black smoke around one or more components. I see quite a bit of power mosfets and high voltage/current transistors on that board... those rarely live eternally. Particularly the 3 mosfets on that heatsink (bottom left), I'd start there - see if one is shot (they normally have their pins shorted when they fail, check with dmm).
https://inprosols.com/wp-content/up...-A20B-1001-0120-Board-Tested-164424034557.jpg
TM1
Jan 10, 2009
Oregon, USA
I swapped the whole board out for another one that supposedly came from a running CNC (eBay). I can check the MOSFETs tomorrow but it seems unlikely both boards would have the same failure.
Human
Jan 24, 2022
I get it now. Did read control drive front board in the OP, had me confused. Wow no alarm, don't you love some good old EE with poor self-tests.
Ruled out the pot's contacts/resistance?
TM1
Jan 10, 2009
Oregon, USA
This model has a stepped switch instead of a actual pot. I looked up the inputs in the ladder and could see all bits changing as I rotated the switch. Plus it does it on m codes also.
CITIZEN F16
May 2, 2021
I didn't think that style showed the rpm, so I never checked. I'll look at that next. On the controller it shows 43 rpm.
What is the model of the Spindle Drive? Some of them you can change what is displayed by keypad in puts.
Vancbiker
Jan 5, 2014
Vancouver, WA. USA
Was there any memory loss or parameter messing with done? Is this a new to you machine or have you had it running a while?
Spindle speed control is often a combination of CNC and PMC parameters.
TM1
Jan 10, 2009
Oregon, USA
I checked all the parameters on the drive, and entered them into the new board. They were the same as notes I had. Machine was running good, had gotten mice in it, but I repaired all the wiring. Most of damage was in the crt console. I've gotten everything else working and the spindle issue popped up. I can't find any more wiring issues. I'm thinking possiblity an issue with the pcm but unsure how to test it. If I remember correctly the f's and g's in the ladder show the communication of the PMC, but I can't find my manuals that show that.
MwTech Inc
Feb 6, 2005
Fishersville VA
You say mice?? Little buggers will mess up a lot.:mad5:
Just went thru that on my VMC i picked up this fall.
I thought I had repaired all wires but it only takes 1 to have something not work.
And yes I did miss one wire in a 50 wire bundle:willy_nilly:
But after i found it all started working.
You could have a wire that was chewed and now that you were in the harness it is open................
